#320357 - 15/03/2009 01:36 "could not connect socket" error...mk2 ver 2.00 beta 13
damon-m3
Loc: Fort Collins CO
I have been going nuts for the past 4 hours trying to fix this problem.
I have searched the posts and found a topic on this but didn't undertand what to do!
The player is only seen through the ethernet cable connection. Not USB or serial.
Once the player is found, I try to open it and it says "could not connect socket"
I bought a USB to serial connector to try to update the players firmware, can't get that to work ether!
I have never had problems but haven't updated the music on the player in a year or so...
The player works fine otherwise.
Thanks everyone!
Edited by damon-m3 (15/03/2009 01:46)
#320362 - 15/03/2009 08:28 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: damon-m3]
StigOE
Are you using the correct serial cable? You need to use a null-modem cable when you connect to the player.
Are you using the correct USB driver?
USB to Serial adapters are normally not working for updating the firmware. Some are working, but it seems most are not.
Stig
#320365 - 15/03/2009 16:09 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: damon-m3]
If Emplode worked via ethernet before, but doesn't work now, there is a chance that the Windows Firewall is getting in the way. See if this fixes it.
Other possible problems include a mismatch between the player firmware version and the Emplode version. As you have surmised, you need to solve that serial port issue if you want to upgrade the player firmware. However, you don't need to do that simply to find out if the two versions match. Just hit the "About" screen on both the player and on the PC's Emplode software. If they both say 2.something, then that's not the problem. In fact, if your player is running 2.00 beta 13, it's already running a good version and you don't need to do anything else.
#320372 - 15/03/2009 18:23 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: tfabris]
damon-m3
Well...I just updated the firmware with a null-modem and gender bender for my USB to serial cable (two trips to radio shack) and now when trying to open the player it displays error code 0xc0041002 "download failed when checking database". I think I am using a regular ethernet cable, the one that used to work! Do I need to get a different cable?...
Im about to thow this off a building!
#320373 - 15/03/2009 18:31 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: damon-m3]
damon-m3
And I tried the tips that you reccomended and to no success. I am now running emplode for ver 3 and version 3 beta 11. I just don't get it!
Thanks for the help,
and I hope you guys can help me solve this issue...
#320374 - 15/03/2009 18:43 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: damon-m3]
Do not use Emplode version 2.10. Do not use Empeg firmware version 3 alpha. The new error you are getting is because you switched to the alpha versions... Don't do that.
Put them both back to the known-good version 2 stuff you had before; that should have been fine. Player firmware: Either version 2.00 final or Version 2 beta 13 from here. Emplode: Version 2.00 final. Use only those.
#320431 - 17/03/2009 17:53 Re: "could not connect socket" error...mk2 ver 2.00 beta 13 [Re: tfabris]
damon-m3
Ya, I've been using the new firmware and really don't like it! I will be out of town till next wekk, but when I get back I will give these problems another go!
Thank Tony for the help, you're a great resource!
